Wandering at low speed.
Philster
When puttering along at 'no wake' zone speeds, my boat will not track straight. She goes a little left or a little right. Requires constant steering wheel input.
>Bravo 1.
>Three-blade SS prop in mint condition.
>I do not have a finned zinc anode on cavitation plate, just a flat one.
>Skeg is 95% fine (although I've heard skeg doesn't matter much anyway).
>No list.
Also:
I putter along with tabs all the way up and outdrive all the way in/down.
I am making 900-1000 RPM at puttering speeds in no wake areas.
Any ideas?
capndan
Re: Wandering at low speed.
My understanding is that is pretty typical of Deep-V hulls.
especially big ones.
Have you had this boat a long time? Is this a new problem?
bear_69cuda
My boat does the same thing but if I hold the wheel still, it corrects itself.... Have you tried not correcting to see what happens?
redone4x4
+1 on this. If i hold the wheel still, the boat wanders left and back to the right repeatedly. How about lowering the trim tabs? you say you have them up. When i put my smarttabs on, almost all my wandering was gone.
dingbat
Try trimming your drive up a bit. Excessive trim at slower speeds will make mine wonder everytime.
jkust
Until I owned an I/O I didn't know there was such a thing as wander. My OB's don't do it. For my I/O I finally realized one day to quit correcting it and you will go in slight zig zag straight line. I don't even notice it anymore in no wake zones.
Philster
Second voyage on the Scarab. Had my maiden voyage in fall and it did it then, too.
Hey, I don't mind any quirks if they are normal. Believe me, be it a sports car with 40 series tires that wander or my R/C nitro race cars that overreact to steering input, as long as it's normal, I am fine with it.
jbjennings
My outboards do it too. I don't know why, but all boats seem to do it to some extent. Seems like the bigger the outboard, the worse it is.
Normal stuff, though.:)
JBJ
Home Cookin'
my sister's wanders: 19' Grady CC (deep v) with a 150. But mine doesn't: 21' CC deep v with a 150. But I read about it: many boats do this and trying to correct usually makes it worse.
smclear
JBJ
A true inboard (not I/O) does not wander like this. The rudder prevents it. This phenomenum only occurs in I/O's and I guess O/B's too.
reap182
Mine does the same thing, try not to overcorrect and should do slight left to right.
CHAWK46
Thought it was just my old Imperial Cuddy but my new to me Century BR does it but not as bad. My OBs never did it.
KermieB
Same thing.. I hold the wheel straight and trim up pretty high. The slower I go the more it rocks trimmed all the way down.
bekosh
>Bravo 1.
>No list.
Also:
Any ideas?
My Wellcraft does the same thing. Very common for deep V hulls. Trimming the drive out slightly helps a little, but I have found that dropping the tabs all the way down makes the biggest difference.
dannyual767
posted by bekosh,
My 2004 Stingray 200LX used to have horrible low speed wandering characteristics. I installed stainless steel Nauticus Smart Tabs and like redone4x4, almost all of my slow speed wandering is gone.
scipper77
I always thought that my boat wandered because I have power steering and that means I get no feedback from the wheel. Because I have no feedback I can't tell that I am overcompensating to correct the wander causing me to eventually wander the other way.
Triton II
My Ocean Series 580 wanders slightly and has fairly "mushy" steering response below about 5 knots constant speed. However if I select neutral she track straight. I may try fitting trim tabs, but in all honesty I've got used to it and treat it as part of her "charm".
TII
spudshaft
"Classic" example: my '82 19' Ebbtide does it too. Makes docking and getting on the trailer interesting at times.
Shife
Tabs full down at no wake speed. Problem solved.
