wvmedic
- Jun 3, 2008
- 516
I was attempting to test the warning buzzer for my 1995 E90TLEO Evinrude on a 1995 Crestliner Sportfish 1750.
The buzzer under the dash on the 170 sounds for a few seconds when I turn the ignition to on.
But I am getting no warning buzzer when I ground either temp sensor. I am getting voltage to the tan wire at both temp sensors and to the VRO circuit. I haven't tested under the dash as of yet. Any ideas as to what the issue might be, not sure if this is a common issue or not.
The FSM doesn't show a diode inline that I can see that might have malfunctioned. I'm also not sure if the buzzer under the dash is the one that should sound or if there is a separate buzzer in the control.
I've searched the forum without success for an answer, only a couple posts with said issue and no answer as to what it was.
I know I ask a bunch of questions and I do appreciate you fine folks helping out with you're knowledge.
Jeff
Jeff
