ajgraz
- Mar 1, 2010
- 1,858
Re: Was I in the wrong?
This nails it. Without the day signals (as infrequently as they are used) to signify that you are "not under command" (or anchored, or in distress, as the case may be) the sailboat must assume that you are under power; therefore, unless the sailboat (believed he) was "overtaking" you...that is, coming directly onto your stern, he must assume that he is the "stand to" vessel and that you are the "give way" vessel.
Though I also agree with the guy who said 12' is cutting it too close.
That said, I've gotta get me some day signals, because sailboats "buzz" me all the time on San Diego Bay while I'm drift fishing. One day one of those sail boats is going to hit me, and I'll technically be at fault unless I get some proper day signals.
Well, ..... As they say, ignorance of the law is no excuse. (Just because someone doesn't know what a day signal is for a vessel not under command or under way (two vertical black balls), doesn't mean they are not obligated to use it.)
The down side of the sailboat taking premature evasive action is that the power boat will not know that the sailboat is taking such action, and this may put both vessels on a path of an unavoidable collision.
