wate presume gauge
philbullet
If u where to hook up a water presume gauge from lower unit pump where would u hook up to?
Out boards hook up to the block.
Ayuh,.... Same with an I/O, on the block side of the t-stat,.....
philbullet
Thanks Bondo, but would that be for circulation pump on motor? I was wanting to monitor lower unit pump presume like I do on my outboards
philbullet
4.3 Alpha Gen.11
I have a oIL cooler there, I'll check and see if there s a
plug on it.Iam sure there is for drainage.
Thanks that was the info I was looking for.
