Water coming into bilge
Jakem
I replaced the bellows and also redid the y pipe. I put boat in water and there is a steady stream coming from just above the top y pipe bolt. Any suggestions
Rick Stephens
Leaking when in the water or on muffs?
Broken speedo hose? Loose or bad water inlet fitting? Did you remove the drive again and see if the bellows has again taken in water? Can also be a transom seal. A rotten transom or a broken bolt.
tank1949
water over damn now, but after my transom rebuild, including new y pipes connected, I filled my bilge to almost go into gimbal bearing with tape water and checked for leaks. U sure that your y pipe gasket (o ring) didn't slip??????
kenny nunez
Another possibility could be the rubber ring that seals the upper driveshaft housing to the inside of the bell housing. If the ring was not glued in or was pulled down when the drive was installed.
Jakem
I haven't ran it on muffs yet.still waiting for dizzy. It's leaking below the drive shaft and above y pipe. I haven't pulled drive yet but I guess I will
Ayuh,...... Sounds like the lower bellows drain,......
Jakem
Alright...I pulled outdrive and there is water in the exhaust bellows..none in drive bellows...o ring still inplace
Jakem
My suspicion is the top portion of y pipe isn't sealed correctly as the water leak is coming from the top
Jakem
Here are some pictures of y pipe. I ran water down both pipes and water was going into bilge.
Bt Doctur
there are 2 vent holes in the housing the one you see is at 12:00 ,the one you dont see is at 6:00
tank1949
both surfaces don't look smooth. They need to be a smooth as possible. Did you forget or dislodge the smaller o rings.
Jakem
The orings were still in place...the roughness is silicon. I'm not sure what you mean about vent.holes
Jakem
I used red rtv and it isn't really all that stuck so I'm to believe it isn't the right sealant
Jakem
That's what it looked like when the engine was still in. I pulled engine and the drive. Ran water with a hose down both exhaust pipes it it was leaking out the bottom. Mine looks different then that pic...2 round holes. 1 big one and has o rings. They were all still in place. Now if running water only down the pipes isolates that center peice as the issue right
Bt Doctur
running water from inside and seeing a leak at the Y pipe connection is :
a corroded Y pipe
a corroded transom housing
a missing O ring
Jakem
Now the fact that the inside of drive bellows was dry rules that out...and the exhaust bellows was wet and a bad seal at y pipe allowed water into bilge. Sound a out right?
nola mike
Exhaust bellows is always wet. IDK off the top of my head what/if any sealers are supposed to be used on the y pipe...
