Water exits on ear muffs?
paulgp6022
Is water supposed to come out of the shift linkage area at the lower unit when running on the muffs? Thanks for any info<br /><br />2003 75hp merc
roscoe
Re: Water exits on ear muffs?
The exhaust leg is just an empty box, and there are holes in it. So some water comes out the holes. <br /><br />When my motor is on a fast idle, it pumps so much water, faster than it can drain, that the exhaust housing will fill up and water comes out the top of it.<br /><br />As long as the peehole is working, and the engine does not overheat, then the water tube must be attached. So the water coming out of the drain holes has already circulated thru the engine.
paulgp6022
This is good to hear considering that the motor is two days old! Thanks!
