Water flow question 92 evinrude 9.9hp
Corona kid
Hello everyone :
I just purchased a1992 9.9 evinrude 2 stroke engien my
Question is I put the motor in a large bucket of water and
And started up the motor and did not see any water comming
Out of the water spout. Then I hook up the bunny ears and
Then I get water comming out of the (pisser) is this becouse
There is obvious pressure comming from the water hose? And
Any suggestion's on what the the problem could be if there is one
And how much it might cost. Thanks to all look forward
To hearing from you
the machinist
Re: Water flow question 92 evinrude 9.9hp
Welcome to iboats.
You probably need to use a larger bucket so that water is high enough on the lower unit to allow water to enter the water pump, which is usually at least up to & over the cavitation plate.
When using muffs, be careful to modulate the pressure from full household pressure so as to not blow gaskets or seals.
If you need more help respond back here & othergood guys will help, or go back to the Frequently Asked Questions on the start of this forum & on the 2nd page you will find a link to my LeeRoy's Ramblings to 9.9/15hp OMCs. There I cover a lot on these motors.
Or just google leeroys ramblings
kbait
I've had 'em '****' great on muffs, but not in a barrel (deep enough to cover the waterpump 'bulge'). Changed out the impeller and all was well. You kinda bypass a weak impeller w/muffs. Also, make sure the stainless plate the impeller sits on is nice and flat.. otherwise it won't seal.. or pump effectively. Good luck!
Corona kid
Thanks to all you're info is helpful thanks guys!
