Re: Water in # 4 cylinder!!
It could be caused by lots of things. Bad manifold or riser (common) bad gasket between them (common), water coming up the drive and into the manifold due to defective shutters in the Y pipe (since you are probably on a trailer when this all happened, not likely) rain down the carb and the valves are open on #4 (seen it before)<br /><br />But after reusing a head gasket, that would be the very FIRST I would look at and replace.
