Hi All! My wife's beloved '66 Searay has a recently rebuilt 1967 95 Mercury. The motor was done by a reputable shop and all new recriprocating parts (crank, pistons and con rods). The work was done in 2010 and the motor probably has 20 hrs since. Chesapeake Bay use, so its brackish water but flushed after each use, lift stored, warehoused in the winter.
After sitting two weeks it would not turn over on the starter. Using a breaker bar I wiggled the flywheel back and forth and got it turning, a little time and some oil and it cranked well without plugs. I got it started on muffs and it seems OK except I am seeing water on #3 & 5 plugs. Compression is 125-130 for all six. My guess is the water started the rings corroding making the motor tight.
I suspect the exhaust side cooling cover but though I would check here. #3 seems pretty high up for water coming into the exhaust, I would expect it in the lower cylinders. Could it be the head gasket? It doesn't look like cooling water flows through the head but I could be wrong. Is it possible to pressure check the cooling system for leaks to confirm before I take the cover off?
Any advice is appreciated! Trav
