Howard Sterndrive
- Nov 5, 2008
- 4,603
Re: Water in cylinders. Yikes!!!
if the former, then nothing was pressurized.
If the latter, then the manifolds sure aren't the issue.
and water was pouring out the exhaust during this test? or you had the water lines to the exhaust manifolds blocked off?I connected a water hose to the the incoming hose line from the outdrive to the thermastat housing. This pressuzied all of the motor water passages
