Water in Cylinders
alldodge
Once the drive is removed the coupler comes with the motor. The one thing most folks forget are the ground connections. These connections come from the battery and also to/from the transom plate. The outdrive lube bottle stays with the boat not the motor. The power +/- cables to the trim pump go to the starter post and engine block for the ground. Just go slow and keep an eye on things, you should be fine.
shaw520
Theres also the 1" water supply line coming from the gimble up to the thermostat housing.
