SweeperForce
- Feb 7, 2010
- 487
Hello,
All summer I have been fight with my gear case trying to keep the water out. After each run I have to drain the oil/water mixture. At $12 a quart this got expensive. I pulled the bearing cage out and everything looks ok. To my understanding the only way water can get in is either around the cage which should stopped by the rear cage ring or in between the cage andthe prop shaft, which should br stopped by a seal. I intend to rplace both rings and the seal. Is there any thing I am overlooking?
Thanks,
Tom
Thanks,
Tom
