water leak
bdarbyups
engine starts and water is coming out of the thermostat wire next to # 1 spark plug, is that a replacable part?
Sorry the motor is a 1990 Merc 40hp 4cylinder SN OC225906
Barnacle_Bill
Re: water leak
Sounds like that might be the heat sensor which is replaceable. Always tell us the motor specs so we know exactly what you are referring. to.
Faztbullet
Re: water leak
If its the crossflow 40,that is the water jacket gasket and yes its replaceable and replacement part # is 27-856729. If its the looper 2 cylinder the casting is cracked as water jacket is molded on to block.
