I just purchase an Evinrude 15Hp Ele. The ower said it worked okay.
When I put it in a barrel, there was only a fine spray of water coming out of the pee hole.
I ran a weed eater line down the pee hole without any difficulty. I hooked a hose to the pee hole and back flushed the unit with water coming out the bottom.
I was trying to look at the impleller but don't know how to unhook the linkage. Also I noticed on the lower unit behind the propeller there are 5 holes with screen wire behind them. The hole on the bottom looks to have been drilled out or perhaps thats the way it should be without the screen.
My questions are:
1. The fine spray mist from the pee hole, should that be a stream?
2. How do I unhook the linkage?
3. What Year is the motor?
4. Should I be conserned about the missing screen wire on the bottom hole?
5. Is the barrel causing the problem and will go away when I get on the river/lakes?
Thats again for your usual support of us older people.
My questions are:
