My 05' 60tlrd Yamaha suddenly stopped pumping until I put it in fast idle. Then I could cruise on but, fast idle on each move. It has never been in the shop. I installed a Yamaha water pump kit. I was suspecious because every thing looked good. Went fishing and backed into the launch. Started the motor and it pumped emmidiatly. I completed the launch and it shifted OK. Ah, success! Not, the first time we moved it did exactly the same thing, had to use the fast idle to get it pumping. Proir to changing the pump I had removed the intake louvers and flushed the motor between trips. I did not use the flush "muffler" after the repairs as I thought it might blow off the water tube. Now what??
