water pump
Re: water pump
????----What motor ?-------They are not all the same.
dazk14
Ensign
Re: water pump
Answer Racerone, but it would be more rare to need replacement.
3 years ago, was just the impeller replaced or also the cup and plate?
dazk14
Ensign
Re: water pump
Complete Pump in Freshwater....Your fine... Unless some dope decided to run it out of water(dry).LoL
boobie
Re: water pump
The blades can take a set from sitting and not being used which means they will break easier. Using it more often is better than leaving it sit. But it's your decision.
HighTrim
Re: water pump
I agree with Boobie here. It is irrelevant if it was used little, as he stated that is worse. They do wear from use, but worse, they break from sitting. Rubber dry rots right.
Ever had to pull chunks of rubber out from within a powerhead? Not fun. My 2 cents is to just do it.
