Water separator
El Gaffer
What water separator do you guys recommend?
I will be running a Johnson 150 and Johnson 9.9 2strokes. I plan to mix the fuel in the tank.
Thanks
Moserkr
Chief Officer + Starmada Splash Of The Year 2021
Got mine right here from iboats. Sierra water fuel separator. Not worth buying a knock off when it comes to fuel systems. Sierra is well known at least. Im running a 75hp 2-stroke 80’s johnson.
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
dingbat
Most outboard manufacturers recommend a min.10 micron filter. Yamaha recommends using a 5 micron filter.
Filters are are one place not to skimp.
If you have an existing OE filter head, Racor makes a screw-on replacement for both Mercury and Evinrude filter heads with or without the clear drain bowl. Racor S3213 (Evinrude)
If you don’t have a filter mounting head, buy and install a inexpensive head and install a Racor S3213 Marine Clear Bowl Fuel Filter.
SHSU
From what little I can see, that is an amazing boat!! Such a clean look. Really like it!!
SHSU
El Gaffer
Thanks SHSU, it's been a slow project. Here is a pic from a couple months ago. I scored that tower for $100, gonna make a shade canopy for it and rod holders. Pull the little ones around too, planning to hang my motor in next couple weeks. The old Shakespeare isn't cutting it🤦‍♂️20210321_183053.jpg
SHSU
Electric only lake?
Did you replace the transom sheet with a new sheet of aluminum or did you just cover it with another?
SHSU
El Gaffer
It's for my paddleboard, a Kaku Voodoo, a great fishing platform.
I covered the old one. I wire wheeled it and used a tube of 5200.
