Dunaruna
- May 2, 2003
- 6,027
Re: water temperature gauge problem
csanna, read the entire thread - new OEM thermostat & sender installed.<br /><br />Kopycat, when you grounded the wire at the sender end, did you also wriggle and pull on the loom at the same time? Your eratic readings happen when you slow down suddenly or fire up the motor etc (your words).IMO an electrical connection is playing up in relation to physical movement.<br /><br />Aldo
