water weeping thru hull
barnyard
After pulling engine on 93 23' larson cutty I noticed water weeping into boat down low in oil pan area. very slight, would probebly fill shot glass about 1 hour. Bad, very bad or will it dry out? boat is on trailler. little water in bilge when i uncovered recently
alldodge
If the water is coming from a area that caught some water and now that it's on the trailer is leaking down, then no issue
If it's leaking out of the hull/stringers then that's bad. It won't completely dry out and mold will start. After mold starts it has to be cut out to stop it
