I heard about using a vinegar & water combination to spray on your boat to remove water spots after pulling the boat from the water.
I have heard that this works about the same as the Ducky brand spray and a lot cheaper.
Does any have any experience with this?
What ratio of vinegar to water?
Do you use regular white distilled vinegar?
How does the vinegar and water compare to the Ducky spray with regards to wax removal on your hull? I would assume the V & W mix is not as harsh.
Thanks!!
Thanks!!
