Waterspot Removal - Water/Vinegar Ratio
Sea Ray
I heard about using a vinegar & water combination to spray on your boat to remove water spots after pulling the boat from the water.
I have heard that this works about the same as the Ducky brand spray and a lot cheaper.
Does any have any experience with this?
What ratio of vinegar to water?
Do you use regular white distilled vinegar?
How does the vinegar and water compare to the Ducky spray with regards to wax removal on your hull? I would assume the V & W mix is not as harsh.
Thanks!!:D
ziggy
Re: Waterspot Removal - Water/Vinegar Ratio
i didn't have so much luck with vinegar and water. i use ucky ducky brand. it does remove water spots........don't know about how it effects wax. i just waxed my boat the other day. coulple times out since. ucky duckyed after gettin it slimed last time i was out. literaly. after a wash of corse. while swimming out in the middle of the lake today i noted nice beads of water on the hull.........
