lckstckn2smknbrls
- Sep 18, 2008
- 1,114
I have a small boat and trailer 14" jon and 25hp motor. Is there a way to to get the weight using a bathroom scale?
Will this be fairly accurate?Ayuh,...
Keeping it reasonably Level,...
Weight each wheel,+ the jack or neape,...
Then add up the 3 #s to find the Total...
Sure, as long as none of the weights exceeds the capacity of the scale (usually 300#). If you want to be even more accurate, prop up the other two weighing points with something of equal thickness to the scale as you weigh each point. That will mostly eliminate any errors from weight transfer away from the point you're weighing.Will this be fairly accurate?
Thanks
Go to a truck stop when they are not busy. Tell them at the fuel desk what you want to do. Take your trailer and place the wheels on one platform and the tongue on another one. Pull your truck off the scale and have them weigh it. Make sure your tongue is at the same level as when hooked to the truck.
