Westerbeke Generator 7 Kw Overheating
CAPTKEV85
Im Leaving To Hemlock Cove Today And My Gene Is Overheating. Thermostat Is Working Fresh Water Pump Working. I Put A New Impellor In The Sea Water Pump. Still Shutting Down. Any Ideas????
Re: Westerbeke Generator 7 Kw Overheating
Ayuh,....
Follow the Water Flow,+ Verify where it's Flowing, to where it Ain't,....
Then remove the Blockage....
CAPTKEV85
I Just Found Out The Riser Is 22 Years Old I Think Thats The Prob
Fireman431
Also check for exhaust restriction(s). Some earlier ones weren't using stainless sleeves and corrosion was creating blockages and causing overheating (happened to me).
CAPTKEV85
Well Hopefully When I Get Home It'll Work Thanks Guys For The Help
