Whale tail Question
Status
Not open for further replies.
Bellasdad
I bought a pontoon boat that has a Mercury Classic 50 on it and the previous owner put a whale tail on the motor . Will that help or harm the performance of the boat ?
aspeck
I am thinking it is just additional drag on your pontoon. I would suggest running it with and then without. My bet is you will leave it off.
Scott06
Purpose of the whale tail is to provide lift at the stern. 50hp on a pontoon, makes it wishful thinking
These two are spot on. I ran a dole fin on my previous boat (17 ft sea ray 3.0). It did help with planing until it cracked my cav plate…
on a 50 hp toon any improvement it wishful thinking. Try it with and without, if it does any thing positive would suspect that it is covering a motor height issue or other setup problem
Davetowz
Never had a use for a whale tail, Usually used as a bandaid for other issues. That said, run it and see, unbolt and run again, Post your results.
jbcurt00
It's been more than 8mo since Bellasdad was on iboats,
Avoid posting to old inactive topics
Closed
Status
