Re: What are good cold compression numbers?
I'm finding out that the compression numbers are for a new motor or a motor with a fresh rebuild. Another issue with mine is that it hasn't run enough in the last 2 years to reseal the rings. The last test gave the cylinders a consistant 120psi with a bump up to 140 or 150 after squirting WD40 in the cylinders. I've been told that my tests are essentially worthless until there is some recent run time on the motor and that my numbers aren't terrible - just the sign of a worn but not necessarily worn out motor.
Sound good -
I saw this on the internet for testing the low compression cylinder:
All a "wet test" entails is a bit of oil in the low cylinder...
11. Add one capful (1-2 tablespoons) of oil to the cylinder with low compression.
12. Let it sit for a minute to allow the oil to flow down and coat the sides of the cylinder and piston. If there are any gaps in the rings, the oil will seal them for the next few minutes.
13. Crank the engine for 4 revs, remembering to floor the throttle.
14. If the reading improved significantly (more than 30 psi), your rings are probably worn.
15. If there is little or no improvement, take it to a garage that can perform a leak-down test to determine where the compression is escaping (intake, exhaust, crankcase, gasket, etc.).
16. Replace the plugs, preferably in the same cylinders they came out of. You may want to clean or re-gap them first, or put in new ones. A dab of anti-seize on the threads would be a good idea.
don't know if this is valid info-
ed
