what are my possible issues
marzoid
1985 mercury 75hp 4 cyl...2 carbs
Trying to get my boat running
It wont spark and turn over
I have compression....all 4 spark plugs working....fuel....
But I have noticed that throttle lever and the spark advance lever do not move at all when I try to start
the carbs dont move open or closed because of this
what could be the problem?
FLATHEAD MAC
Re: what are my possible issues
IS THE MOTOR TILLER OR REMOTE CONTROLLED, could be bad cable or linkage.
Faztbullet
No spark could be: (A) defective mercury tilt switch (B) bad stator (C) bad switchbox (D) remote kill switch activated....
marzoid
it has spark
on all 4 cylinders
ONERCBOATER
how much compression does it have? when you say "it has fuel" do you mean that there is fuel going to the carbs or do you mean that you know for a fact that fuel is getting to the cylinders? I ask because if you have spark, air, fuel..... you should have a bang even if weak. Will the spark jump a 3/8" gap with a nice blue color? have you tried squirting a tad bit of fuel down carbs? could you have possibly sheared key on flywheel.....thereby being so out of time that it will not start?
just ideas... please listen to others before me.
Sean
CharlieB
We have to use the right words to understand each other correctly.
Do you mean that the motor will crank and has spark on all plugs, but will not fire and start?
Are you raising the fast idle lever or throttle control and the throttle/timing levers do not move?
Shift into gear and open the throttle WOT, if the throttle/timing levers do not move the cable or control is broken and needs inspection/replacement. A fast idle lever only moves the throttle a small amount and you will have to watch closely to see the movement.
marzoid
it was my harness wire that ran to coil 1 and 2
just incase someone else runs into this problem
