findinghomer
- Nov 7, 2009
- 271
Ok the backstory, I had to replace my complete outdrive. I had my outdrive off a couple times last year and always checked the alignment, the alignment bar slid in perfectly fine and easily. everything was good. When I got my new Unit, my outdrive would not bolt up completely, to much relief, I realized I just did not have the gimbal bearing aligned properly to the coupler (new bearing) . Once I had it aligned properly , i re checked my engine alignment, and bearing alignment and everything again was perfect. Now it slid right on. I thought I was good to go, but when I tested everything out ,my u joints were clattering really bad when I was in the full down position. Long story short I did not have my gimbal Bearing driven in all the way. But by the time I figured that out , it was too late, I had already pulled it. This was on Sunday, so a new gimbal part order on Sunday will not be processed until Monday anyway, so I figured what the hell, I will just try to put this bearing back in , be sure to drive it all the way in , and see what happens. Figured since I had the tools to install the bearing and also pull it again if need be, I'll give it a try. When driving the bearing back in , my driver got stuck a couple times, really binded in there. Once I had it completely seated and the gimbal bearing aligned to the coupler, the drive still will not go on (alignment bar was tight too). I figured I had just damaged the gimbal bearing when I pulled it, so I went ahead and just yanked it out, and ordered a new . I got the new one today. I installed the gimbal bearing properly and have it driven all the way in. Once I have the alignment bar aligned through the gimbal bearing and into the coupler it's still very tight. Outdrive will not go on. I thought maybe I just need to pivot the bearing some, but I've been pivoting up , down , left , right and the best I can do is get it to where the alignment tool will go in and bottom out into the coupler, but I have to push rather hard. Doing the grease trick, it seems that my splines are not as prominent on the top as they are on the bottom. I turned the engine, same thing. It seems like an engine alignment problem, but I'm also afraid it's something else, because it was perfectly fine before I tried to drive that old bearing in. My biggest fear is that I bent the coupler doing this, but when driving the bearing in , I don't think my tool even reaches the coupler. But I've been messing with this thing for four hours, I was hoping I didn't have to come to this but I am stumped, hopefully you guys can point me in the right direction. I really appreciate you guys!
