redfury
- Jul 16, 2006
- 2,657
The other thought would be to divorce the cap from the hull and slide it forward enough to do the work on the transom. But that mainly depends on the design of the boat. I had my cap off of my boat for well over 3 years in MN. Don't worry about the cap. If you have it supported at the front and back properly, then the snow load won't matter.
In regards to the dust, yeah, it's going to get everywhere no matter what you do. Make sure you have a vacuum bag in your shop vac, otherwise all you are going to do is redistribute the dust with the power of your vacuum, not to mention run all that through the shop vac's motor. Otherwise, grind, sweep and then vacuum up the mess. I bought a cheap dust collector for my angle grinder and ran flexible tubing to the shop vac for part of my final sanding/grinding and it worked okay, but I still had airborne dust. Make sure YOU wear a respirator.
