Stan's Customs
- Oct 30, 2004
- 161
I really perfer I/O boats since I was a waterskier in my youth. However lately I have turned my boating interest to fishing as I am near retitrement age.
I have been a mechanic for the earlier portion of my working days and turned to Custom and Utility Vehicle sales in the end.
I have several boats I've taken on trade and live in an area that older used boats are plentiful. Since I do have a nice repair facility for other types of equipment I will likely use an older boat motor and build my own winter fishing boat that I can leave in out in the weather quite a bit. The two most readily available engines I have is a '92 Yamaha 85 and a 85 hp Suzuki ..not sure what year.
The Yamaha has seen a little salt ..runs Ok, I suspect it needs reeds. The Suzuki was running good when removed from the boat several years ago. Which motor would be best generally speaking...?
I'm going to use a 16' or 17' all aluminum boat with windshields....similar to Crestliner of Starcraft so I'll have a wind break in the winter. Winter Crappie fishing can be good at some Texas lakes, but I have found that Bass or Crappie boats have little weather protection.
I also have access to various Johnrudes of he 80's vintage ...mostly V4's...Are they preferable? I have had bad luck with any Merc I have ever owned...but even they can be had around here.
Any opinions on these motors....?
Thanks ...Stan M.
Thanks ...Stan M.
