Frank Acampora
- Jan 19, 2007
- 12,004
Re: what is the best way to get more power out of a chrysler/force
A couple of relief holes in the side of the lower unit above the anti-vent plate will help with power, BUT: It will make a LOT more noise and here in the US, in most states, it is illegal to install "cut-outs" on non racing boats--ie pleasurecraft registered for recreational use.
AHHH! Jump all over that prop. And if you decide you don't want it or it doesn't work for you, sell it to me.
I have had a 2 blade very similar to that one on my Chrysler. Assuming you have a 15 spline one piece lower unit, you will still need to use the prop thrust washer and will need a spacer or two at the nut end of the shaft.
Look at the photo to see prop mounting and exhaust relief holes (4 on each side)
