mbhoag
- Aug 29, 2011
- 147
OK, I have checked out several speed calculators and propeller slip calculators... but none of it makes sense to me... I understand the most basic of theories... but when I put in my numbers, I somehow come out that my boat should do 72 MPH....
That only happens on the freeway when I am towing it....:facepalm:
So I know if my boat is even close to running the way it should... what SHOULD my theoretical speed be?
Here are my boat specs...
1986 Bayliner Fish & Ski Trophy Bass Boat (17' 10", 6' wide) (Fiberglass)
Max load with 4 people, motor and gear - 1200 lbs (according to dataplate)
I have no clue what the actual boat weighs...
1986 Force 125 motor - 125hp @ 5000 rpm
Operating range 4500-5500 rpm
fore & stroke - 3 5/16 x 2.87"
Gear Ratio 15.26
Engine Weight 300
Propeller - Stainless Steel, Michigan Prop, 3 blade, 15P
So with all this info, what should the boat be able to do?
Thanks!
Gear Ratio 15.26
Engine Weight 300
Thanks!
