What is this bore doing?
will941s
Re: What is this bore doing?
There is a Bosch plant here (Charleston, South Carolina), like 2 miles from my house.
Arkman
boy i can't wait to see this in action
wbeaton
I just love what you are doing. How long until the water tests? Do you have GPS data of the motor on your boat before you began tuning it?
Ostsideend
Hi Wayne,
no i don't.
But today i did the test. Without NOS the tinY Yamaha don't get the short rubber boat into plaining.
With NOS it's an amazing "rocket" and it takes a second to get it planing.
I am obset. It has got a lot more of torque, but up to a rpm border it stops accelerating. I have to have some more rpm. Don't like to win the race yust with a larger bottle of NOS.
Ostsideend
I did some more work. The carb got an intake "trompet" nozzle and i moved the ignition in direction of 8' before upper Dead Point. Got more rpm... Moving this Week end the ignition Point to 12' and then check a fixer point at 30' .i'll See what Happens. Idle rpm was a lot more with 2' plus.
Ordered a 5 lbs nos bottle As well :))
wbeaton
Have you also looked into re-propping the motor? A little adjustment in pitch might give you better performance.
Ostsideend
Won the Race, but with the Second 3 hp Malta. The tuned startet einging the bells.... Don't Know Why. But i will get him Fine during Winter time.
Nos in a 2lbs bottle helps a Lot:))
Pics and Video After comming Home....
Willyclay
The outcome was never in doubt! Congratulations, enjoy the beer while we enjoy the pix and video.
wbeaton
Congratulations. I am a little unclear, though. Did you will with the modified motor or a second stock motor running NO2? Can't wait for the photos/video.
Ostsideend
The the tuned sound became "unsafe" it was the Stock with the cfk Membran and tuned intake, closed decompression bore and a Little more pre ignition Timing. But i had some luck....
Ostsideend
after a while of not beeing here...
Still gamebling with my yamaha malta.
The bore does not have a decompression function!
It is done to get oil and or fuel (mostly oil) which can be collected in the crankcase burned and not let it directly drained into the water via the exhaust.
I am willing to make a self made dyno test up tp 6HP max this winter.
Its based on a rotary brake disk to manually hold a constant rpm and an electronic pressure gauge which will be mounted between the brake piston housing an the backstop on the outboard shaft.
This thing will show me Nm and with having the rpm according tho the Nm reading it is easy to calculate HP.
Setup idea:
Sketch for the rotary adapter arrangement:
I found that a twin malta (2 x 3 HP) will let the dinghi plane. So i do have to reach approx. 6 HP on a single...
It moves:
In motion:
Yamaha Malta offshore schlauchi.wmv - YouTube
The problem is based on to get a 2 meter rubberboat to plain with a 70ccm motor only
Ostsideend
Long time ago, but still a fan of these nice tiny 2 stroke outboards.
A new race will take place and this time i will do everthing 100% right.
I did build a DIY Dyno for the 3HP Yamaha, which i pre tested today. (Just for fun, nothing else)
Larger Carb is already on and an inner rotor digital ignition is mounted.
Hydraulic gear pump based dyno-system pre tested with a power drill...
Vid about the pre test:
https://www.youtube.com/watch?v=W6F1K8IYDhM
Vid about a first step with the digital PVL ignition:
https://www.youtube.com/watch?v=oDeb2dz8I0A
Is there anybody who can explain, or show me a page where it will be explained, how the function of the exhaust works? I am fully aware about tuned 2 stroke exhausts, but her on outboards we do have an open end pipe which ends in a non conical chamber...?!?
Sea Rider
Just leave the engine standard, prop it right with a induction tach to run towards full wot rpm factory stated, throw away what's not needed out of the boat, if you happen to be a feather champ boater and your opponent a fat one, will have an oustanding weight advantage
Sitting engine at the sweet transom height along a correct prop maximization usually towards one less pitch will do the trick..
Happy Boating
Ostsideend
Hi Sea Rider and many thanks to your reply. It is a 1,95 meter rubber boat (about 6 feet in lenght) There is nothing i could throw away exept myself or the motor ;-)
To prop it right is also a problem. There are two props available. The smaller one is on and the larger one works worse.
The hight position is something i will work on. I plan to cut the shaft, take approx 100mm out and weld it togehter again (incl. dirve shaft-, gearshift-, and water supply pipe shortening) due to that the "short" Malta is sitting still way to deep in the small rubberboat. (Think i"ll do a setback and a kind pf jack plate as well for adjusting the motor to an optimal hight and position to hepl to get on plane.
By the way the idea to cut 100mm out of the shaft leeds me to fully understand if the volume or the shaft lenghts matters or if it is the length of the exhaust pipe (open end pipe) matters only.
If i can get no answer to this, i have to do it and see what my DIY dyno tells by comparing between the power curve before and after.
Its all for fun :)
Ostsideend
Hi Willyclay,
thanks!
Good idea! There is one professional prop-shop in Cologne city which is not to fare away. I will show them one and ask what they can do.
it will be good to know the max rpm as Sea Rider said, before they squeeze it down...
Ostsideend
Did a lot of things... and it went not so bad!
7.4 HP @ 5.300 rpm out of the 70cc 3HP Yamaha Malta
https://www.youtube.com/watch?v=XAemR-L8sUc
Power curve:
fetch
