What is this wiring connector?
Tailguner
I have a 2008 Rinker 276BR with volvo penta 8.1 and DPS-A drive. I'm trying to find the trim tilt wiring and I think this connector may be it but looking for confirmation. The connector is connected to a long flat cable that is bundled up behind the engine near the transom in the engine bay. can anyone confirm this is indeed the trim/tilt connector??
alldodge
Not positive from the pic but the wire colors are correct for trim
bruceb58
Likely the connection where you can add a stern tilt switch
Tailguner
2Xs with AD on the color. Does your power trim work?
yes it works but i want to add remote tilt switch using mercruiser part # 87-815200A02. I have read it will work with VP systems so long as the connector is the same.
It would be easy to splice into the wires to install a remote switch.
Scott06
Even if the connectors are not the same you can make your own from -to cable if you go on line you can find these marine and automotive connectors and make up what you need
