Well put her on Berlin Reservoir today. Oil pressure was at 40 lbs idle and 60 lbs running. Motor runs good., Temp was good never attempting to overheat. Got a few miles down the lake and dog house was filling with water. Couldn't tell why. My bilge pump blew a breaker as I had a 110 and a 500 wired to it. So quickly cut the power to the 1100 and run one from the battery/. Reset the breaker and 500 ran good. Connected 1100 and it to was good. Soon pumped it dry. No water coming from any where. So started boat and looked again. Motor is pumping water into blige. Patch was dry, but now seems to becoming from rear of block. Guessing its the freeze plugs behind the Fly wheel.
So next step pull that 3.0 so I can see what the devil is going on. LOL! Before pulling I'll check the cylinder pressure too, Just in cast ings, head gasket or something else needs done too. LOL1
