What or Where do i tap into for Water Pressure Guage on 2005 DF140
jbryan605
Anyone know where to hook up the installation kit to this Suzuki DF140 for the water pressure gauge? I need to install this to make sure when I put a Jack plate on it still getting the correct amount of pressure so I do not damage the motor. Any help on where this should plum in would greatly be appreciated.
Thanks,
JB
jbryan605
Re: What or Where do i tap into for Water Pressure Guage on 2005 DF140
I guess I should have posted where should I tap into on a 2005 Suzuki DF140 to install water pressure gauge?
Thanks
On some motors you can simply "tee" into the tell tale. However, this does not work on Suzy 4-strokes so you'll need to find a water jacket port.
Scrapiron
Not sure on a suzy, but mine is on the top port side of the powerhead just above the port side thermostat. it's connected with a small brass nipple fitting. I would just start looking all around the heads on both sides. it will be small bout the size of an icemake line on a fridge :) GL!
