what plugs are best
bream master
Hi to all,I hve a 35hp johnson sea horse 35el78 manual suggests 2 use champion plug gapped at .030 ,i chose 2 use NGK plugs & was told that spark plug gap is already set,should i stick with using champions or is it ok 2 use NGk............. WHATS BEST :D
bream master
Re: what plugs are best
thanks 4 quick reply,will take your advice cheers.........
NelsonQ
Also, not to be negative, always checking the gapping even on pre-gap plugs. I've had some incorrect gaps even on pre-gap
kenmyfam
I always use champions but that is what is recommended in my owners handbook. Consequently I have stuck with that and had no issues so far.
david_r
does anyone on here run the surface gap i think its a ql16v?
ive seen the heat chart pages and read about the way they tested for proper heat ranges in different shapes of plugs at wot and at idle---the parts store that i shop at doesnt stock the surface gap champion so i bought l77jc4.
can anyone tell me if they have tried both? and if there where any differences at wot or idle?
thanks for the help!
bream master
thanks 2 all who hve responded & will certainly take your advice.....WHAT A GREAT SITE...:)
JB
Please don't hijack someone else's thread, David. When you post the new thread that your question demands, don't leave out the year and model engine you are talking about.
BaitThrower
I was running NGK plugs (BZ7HS-10) for a little while on my '86 15Hp Johnson - They worked fine on the engine. I believe they are superior to Champions overall, but I was getting RF interference more using these plugs than with the Champion QL77JC4, so I switched back to Champions. My sounder and radio work better in my small boat with the Champions. The Champions were pre-gapped to 0.030. The NGK had a 0.040 gap which i had to re-gap down, out of the box.
The only reason i switched to begin with is because the Champions are hard to find in my area. I need to order them in.
NelsonQ
You guys now have me thinking. I had Champions in the boat when I bought it in June but I took it to the mechanic I use. He indicated they were fouled and needed replacement. He used NGK premium plugs (don't know model but the proper NGK replacements) Boat runs fine but I noticed it sounds slightly different (not bad, just a different) but again I wasn't used to its sound prior to it as I only had it one wknd before.
However, I think in the spring I'm going back to the Champions. Seems to be a consensus across threads to stick to the Champions Johnson recommends.
bream master
hi 2all again,took boat out yesterday on d lake and had with me both NGK & CHAMPION plugs.After gapping both sets of plugs at manufactures specs & running motor for 15min intervals each time,i came 2 d conclusion that champions do perform better than the NGK'S on my particular motor & without any elecrical interference.Maybe sticking with manufacturers specs is ::Dd way 2 go.........CHEERS.
