Re: What prop to buy?
There is usually a number stamped in the prop that is either the model number or the pitch and diameter.
For reference, the prop on my 1985 85 hp Force is a 19 pitch. The boat is a 1985 Bayliner cuddy cabin, 16 feet in length. This was a pretty common setup by Bayliner at that time. There are only a few prop manufacturers making Force props, so you will have to shop around. I think Michigan Wheel still makes them, check the iboats propeller section.
