Trying to figure if the correct prop is on drive now. Or if there is a different one recommended. Here is the info i can provide.
Looking for cruising and occasional tubing.
Currently there is a 13 3/4 x 15p Black diamond on it now. (Damaged)
4200-4600 is manufacturers recommended W.O.T. max.
Boat info is 1985 4Winns Candia 170 powered by a 1979 Mercruiser 140 (140hp)
Drive is stamped with 1:98 gear ratio
Approx boat weight by manufactures spec is 1800lbs. (however that would depend on what powerplant, i could not find an exact weight for the boat with the 140)
I have done a couple w.o.t. passes that showed 30mph + but according to my meter. (tach is inop) i was over 5000rpm. This is way unacceptable The boat is freshly tuned with timing and dwell spot on.
Again just looking to see if this prop in a brand new condition would be a correct one for this boat or if a diff. would be recommended.
Thanks in advance,
Tony
Thanks in advance,
Tony
