I just purchased a boat (cheap) with a 1992 Evinrude 40 HP. Model is TE40ELENM and has the VRO system on it. The motor has no compression on the bottom cylinder, the top is 119psi. I would like to know what the normal compression would be for the cylinders for a motor with about 200 hours on it.
The carbs were in synch and the bowls were free from any foreign matter. I did not find any evidence of water intrusion in the bottom cylinder. The only thing I can figure is that oil delivery to the bottom cylinder stopped.
I have purchased a powerhead to replace the toasted one, but I am wondering if there is a way to test the VRO to see if it is working correctly before I install it and run the motor. Anyone have any ideas on other causes of death for this powerhead?
