NoKlu
- Feb 23, 2008
- 786
Looking for info on a pair of 5.7's out of an 1990 3555 Bayliner. These are new to me and I know nothing about them but are trying to get them running and back in the boat. I'm told one should be counter rotating but they were not marked when pulled by a contractor. Just set on ground in no particular order. The first engine we got a good compression test from and the engine spun in clockwise direction. Second engine we spun up and got really bad to almost no compression. We used new starters, both for standard rotation to do the tests. Our Mechanic told us ,if we spun the counter engine, clockwise, we would get no good numbers even if was a good engine. Original starters were seized solid with rust so we couldn't spin those either. The merc dealer claims that the serial numbers on the tags are not serial numbers but another number they do not recognize. The Number is C759898. I believe this to be the counter rotating engine but I don't know how to tell for sure. Both drives were removed and the props are the same rotation. I'ts possible the drives and props, were switched out as this was a salvaged boat. Got it cheap and can put a few bucks in it to get it going. Can anyone check that serial number and tell me if that is the counter engine? I would upload the pic of the tag but it's to large a file.
