what should I check for buying an old mecruiser boat
liusigou
The owner told me following
18 foot 1989 Cadorette bowrider with 4.3 Mercruiser inboard/outboard and trailer. Cylinders compression about 120PSI.
I have some experience to install outdrive,oil change, below mount.
thank you
Scott06
thank you
condition of transom and stringers first, likely on a boat that old the wood structure is rotted. Compression should be 150 when new - this shows some wear on the engine. Watch what oil pressure is when engine is hot. You need 10psi per 1000 rpm of engine speed for it to be in good shape. Look at condition of gear oil in outdrive check for water and or metal
On a boat of this age would expect there are some issue that need repair
tank1949
thank you
transom or/and stringer rot!!!! Trust me!
JonBoat55
thank you
Boat that age, be very wary of ANY soft floor or flexing issues.
