What should I trailer with??
magellan
Re: What should I trailer with??
Mike, it's correct, 2650# is only the boat weight from specifications. With a 600# trailer and some gas it's close to 3500#, the rating for "some" Venture's 2000. That's why I don't like it, it's too tight.
6MISFITZ
If you were taking the boat up or down 400 series highways then you would find the van more then overwelhmed by the hills and passing trucks. If this was a tow to Port Credit Marina and then home in Mississauga it can be done. Again anything front wheel drive must have a transmission cooler if it doesn't already and change the transmission fluid at the end of every season.<br />Mike.
MIKE F
I wouldn't depend on any weight from manufacturers specifications. My boat weights about 400# more than the builder said it would. :eek:
6MISFITZ
Hi Mike F, is that 'cause you have the optional prop? L.O.L.<br /><br />You're right, it never hurts to get the boat and trailer weighed WET, just to be on the safe side.
