What size is my gas tank under floor?
iggyw1
Ensign
I just purchased a 1991 Smoker Craft boat , Magnum 161. It has a max. 90 H.P motor allowed. It has an under the floor gas tank that it was manufactured with. I cannot find any info on what size this tank is in gallons. Can anyone help me out? Thank you in advance!
Bkok33
I saw on a spec sheet it said 14 gallons but I am not certain on it.
tpenfield
If you can get a glimpse of the tank, it may have a label with the capacity on it . . .
Fireman431
Or do the math. L x W x H in inches. Divide by 231 and that equals gallons.
iggyw1
Ensign
Thanks. That is probably it. There was not enough gas in the tank when I bought the boat to get the primer ball hard, and when we filled it up, it took 13.5 gallons, so it probably is the 14 gal tank. thanks again!
iggyw1
Ensign
look it up yourself http://www.smokercraft.com/media/legacy-catalogs
or contact smoker craft and ask.
As stated in my question, I could not find anything about it when I was trying to "look it up myself" Also stated in my question, the boat is a 1991. The link you posted in your reply to me to "look it up myself" went back to 1995. I was under the assumption that this site was for the purpose of getting help from someone that may know the answers to our questions if we cannot find the answers anywhere else. Sorry if I bothered you, sir.
iggyw1
Ensign
Thanks for the formula. I should have learned that in school (& I probably did, back when......) I really cannot get to the tank to measure it, so I cannot try your suggestion, although it is good for me to learn the formula.
iggyw1
Ensign
I can probably get to see enough of it as the opening around the tank if I take the vent grill cover off. I will take a flashlight and look down there. I'm glad you replied and suggested this as I never even thought of checking that out, but I sure will. Thanks.
