Re: what size is my shaft
yep, think if i turn those over, raise it up a couple inches, then move the winch up to match, it would pull the boat forward, getting the rear rollers closer to the transom better fender axle clearance and fix the weight distribution(it's light on the hitch)all in one move
after i do my impeller and lube change i will start a thread in the trailers and towing and get it done before spring. i wonder if i could take it to work on my day off to take use of the lift and air tools i'd be done in an hour. i could put a jackstand up front, a lift pad at each rear corner and lift it right off the trailer, flip the brackets then sit it back down:joyous:
