Re: What to expect from 2 cycle synthetic oil?
The difference between synthetic and regular oils is a whole 3 dollars at the gallon level here, cost shouldn't be an issue. Most of what synthetic will give you you cant see, fouling and BETTER lubrication will increase the longevity of your two stroke.
I have seen first hand crank cases from sthil chainsaws that were tested with synthetic and regular oil, there is no doubt synthetic runs cleaner and prevents buildup better. But oil is oil right?
Where do you live that synthetic is only $3 more than regular TCW3? I'd like to buy some. What oil, and how sold?
Where I live we have:
Walmart house brand TCW3 $7 / gallon
Castrol Super Outboard TCW3 $12 / gallon
Pennzoil full synthetic TCW3 $21 / gallon
Bulk regular grade Johnson/Evinrude $15 gallon
I happen to mostly use Castrol, so it is actually $9 per gallon or 75% more.
Now, if I go to the dealer and buy a prepackaged gallon of non-synthetic OEM oil (Yammie, Quicksilver, BRP), the same oil that costs $15 in bulk, actually it would be the same as Pennzoil synthetic at Walmart, about $21. But who would do that?
I have no reason to doubt the technical findings you're referring to, but the skeptic in me asks: what is the real, practical difference between using properly mixed, regular TCW3 and synthetic in terms of engine wear and cleanliness? Is it REALLY something I'll ever notice in my lifetime - I doubt it. I'm not saying the difference doesn't exist, but is it meaningful in any way to the typical, moderate use recreational 2 stroke boater? If it means an engine lasts 2,500 hours instead of 2,225 is it meaningful or will any of us ever realize it or appreciate the benefit? Frankly, I see little or now carbon build up - with the use I give it - anyway. Should I be rolling my eyes too?
My opinion, is it isn't, certainly not worth the price premium of 2-3X. If it were $3, I'd probably say "why not" and spend the money, but I've never seen it that cheap.
