Re: What to power her with?
I plan on hanging a 1978 55hp Johnson on mine, it's a good solid running motor and I figured that it's lower weight makes it the better choice over say a 65 or 70hp triple. Mine is already set up for an OMC so I'm sticking with it, besides, that's pretty much all I have here other than a few larger motors.
I had the 55hp on my Edinboro, which is slightly larger and it did just fine, but I came across a super clean 110 hp which I hung on it. I don't think I gained all that much in the end, just more stern weight and it's a faster out of the hole. I didn't gain a whole lot of top end. If it did, I'm not willing to push the boat that fast, 45 mph in one of these boats is plenty fast, especially if the water gets choppy.
I'd venture to guess the Westfield would get on plane just fine with a 35 or 40hp with a light load. I've got a slightly smaller Steury 415 that does just fine with a 30hp Evinrude even with two big guys onboard.
The MFG is lighter overall due to it's construction. If the 55 isn't enough, I've got a good 70hp to use, which is the max hp anyhow.
I've always been partial to the twin cylinder motors, I like to keep things real simple. A buddy is trying to talk me into hanging a motor with power tilt and trim. That idea is just fine but it's more weight and one more thing to go wrong. Besides, to be honest, I've never missed having it on any of my other small boats.
I'd probably stay away from a period motor just for reliability and parts access. The OMC engines of that era were electric shift, something that I usually stay away from. I've got a few good 55hp motors outback but the controls were always an issue when they got older.
The Merc 500 or 50hp was a good motor, just pay close attention to the wiring as most older Mercs were notorious for rotted wiring harnesses.
I considered even hanging an original Chrysler 50hp as shown in the brochure since I have a good running low hours motor here but I'd rather have a more modern engine and my transom is now already drilled for the Johnson 55hp.
If I were leaving in all the original seats and restoring this, I'd probably go with the 1966/67 Chrysler 50 but I intend to use this for river fishing and maybe some crabbing. A pair of new back to back seats and some rod holders will be on my to do list.
