I just picked up a nice 40 jonny super quiet qd-22 well this thing is a 1960 the carb has both water and heat exhaust as part of the choke operation, I have heard its not a great system and to just use the manual choke. was wounder should I bypass the water & exhaust, or should I hook everything as original and then just use the manual choke setting to start, If I do bypass the water to carb whats a good way (jumper hose top to bottom?) well what would you guys do? thanks.
