weider1717
- Sep 2, 2008
- 315
I installed a new sending unit...
worked great even still works great but it went fromme turning on the switch and going from dead empty to what the tank reads...
to now when i turn on the switch going from full to what it reads.....
now after I installed this new sending unit it worked like it should i turn on the switch and it would go from empty to where the level in the tank is...
I un hooked and hooked back up the battery a few times while getting it ready for this spring and all of the sudden when the switch is off instead of reading empty it reads vice versa it now reads full and when you turn on the switch it goes to reading tank level correctly.
but why when the switch is off does it now read full? it was reading empty when the switch is off so not sure what happened!?
and no it's not wired wrong...actually there isn't a wrong way to wire a wema sender if you're not using their gauge plus like i said i installed it and it read like it should for days now it's doing the oppoiste when the switch is off.
it still reads the tank level correctly but i want it to read empty when the switch is off not full..why did it change by itself like that?
