What year 85hp Force do I have?
albundy
Yes, I know there are a million of these posts already, but nowhere have I found on the motor the serial number. The bill of sale that was given to me said the Motor had a serial number of 0022F49, and the Block serial number is M618080. The boat itself is 1990, but is there a way to tell from those numbers what the year of the motor might be? I am wanting to replace the impeller but want to make sure I get the right one.
Thanks in advance
Al
albundy
Re: What year 85hp Force do I have?
I am not sure if these numbers are good at all. I cannot find a plate anywhere to get the true numbers. Any info is appreciated.
azlakes
... ya there should be a dog tag just inside the o/b on the collar with all the info.
albundy
Ok, I posted some pics. While I was getting photo happy I did fine a number on the block 498167 is this anything ?? Thanks!!
oh, and the second photo is of where I believe the tag USED to be!
jerryjerry05
Looks like a 1989.The motors were all basically the same the paint and decals were the main difference,J
jkust
Show the motor cover.
albundy
Ok, here are some pics of the motor cover. I hope this will help determine the year. The boat it is on is 1990. I am wanting to replace the impeller and want to make sure I get the right one. Aren't most of these year models the same impeller?
MWBROWN
I looked up I-BOATS impellers and is shows the same impeller for
all 85 HP engines.
They don't show a 1990 85 HP engine.
Mercruiser.com has schematics of engines and you could determine
what your part number would be from there.
Also, Crowley Marine website.
Good Luck,
Mike
jerryjerry05
If you deal with a Merc dealer they might try to sell you the wrong impeller.They try to sell the impeller for the Merc/Mercruiser motors.It looks just like it only bigger.Take the old one with you when you go shopping.J
albundy
Thanks for the info! That was going to be my next plan just take the old one with me. I appreciate all the great info that is on this forum.
albundy
I removed the old impeller and it is a 3017. The housing has a top and bottom gasket. The one that is supposed to fit an '89 model is the 3030. The guy that I went to for parts asked if someone had put a newer lower unit on the motor. Good question! Now I don't know what I've got! lol
