what year is my Johnson 70 hp??
johnnyo34
I'd like to find out what year my Johnson is, J70TLCNB,
did a search but couldn't find it.. I need the bottom gear case for it & wondering if a 1978 70 hp gear case or leg would fit.??
thanks in advance...
John
BKS72
Re: what year is my Johnson 70 hp??
Its an '82 based on the serial number. Gearcases have different P/Ns but I don't know if that means they wont cross. P/N for your gearcase is 0392471 and the one on the 78 is a 0388753. Both of those numbers are for the 20" unit.
johnnyo34
Thank you very much. Wonder where I could check if these Part numbers will cross..
John
Daviet
Check out the "Top Secret File" sticky at the top of the page, there is a conversion chart there.
BKS72
Keep your eye on eBay. You should be able to find a lower for 300 or less. I lucked up and got a lower for my 95 '115 for $107 shipped :)
johnnyo34
Thanks, I found a lower for a 1982 70 hp, & the guy says the shaft is a 4 spline, but he says there also are multi spline... Is this correct, & if mine is a multi spline, can I exchange mine with the 4 spline. I don't have mine out yet..
BKS72
I don't believe you can without swapping the driveshaft or the crankshaft. The splines on the unit you're going to put on it have to match the splines on the crank.
